Discussion topic: No broadband
This message was authored by: homeworker
No broadband
Live in SR3 area of Sunderland and we have no internet but site says no issues
Re: No broadband
@homeworker
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it ~ it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later).
