Discussion topic: No broadband
Message posted on 19 Aug 2025 07:19 AM
No broadband
The broadband has been down all night, yet your checker says it's working. The hub is showing one light that switches between green and red
Message posted on 19 Aug 2025 07:22 AM
Re: No broadband
Please call as the issue is affecting my working from home
Message posted on 19 Aug 2025 07:30 AM - last edited: 19 Aug 2025 07:31 AM
Re: No broadband
No one will / can phone you. Your Community tag name isn't linked to any Sky accounts you have so no one knows who you are. Also, you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
