Discussion topic: No broadband
Message posted on 31 Jul 2025 07:47 PM
No broadband
I've just switched to sky and followed all instructions to start up. The hub is on and WiFi is on but no internet. I've troubleshooted but still no joy
Message posted on 31 Jul 2025 07:52 PM
Re: No broadband
Are on the lights lit on the hub ?
Message posted on 31 Jul 2025 07:54 PM
Re: No broadband
The power and WiFi but not the internet
Message posted on 31 Jul 2025 07:57 PM
Re: No broadband
When was your activation date ?
Message posted on 31 Jul 2025 07:58 PM
Re: No broadband
Today I had a text to say it was active
Message posted on 31 Jul 2025 08:02 PM
Re: No broadband
@Heatheramh What is the hub connected to by cable, and is the old ISP hub still working?
Message posted on 31 Jul 2025 08:03 PM
Re: No broadband
Its connection with the Ethernet cable provided by sky. The old isp is still working
Message posted on 31 Jul 2025 08:07 PM - last edited: 31 Jul 2025 08:10 PM
Re: No broadband
@Heatheramh If the old ISP hub is still working and you have a broadband connection on it leave it on and working at present!
Electronic version for connecting and installing a sky hub. Just follow the yes i have Internet calls, ignore the phone plug in if not using!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 31 Jul 2025 08:20 PM
Re: No broadband
Thank you. I'll have a go with your suggestion but probably in the morning as I'm weary of trying today. I've been looking for answers and trying to get in touch with sky most of the day. I'll update tomorrow. Thank you.
Message posted on 31 Jul 2025 08:26 PM
Re: No broadband
Then despite what the text told you it appears that changeover has not taken place yet so keep your old ISPs router/hub plugged in and when this stops working then connect up your Sky one.
