Discussion topic: No broadband
Message posted on 17 May 2025 08:03 PM
No broadband
Hi
my broadband suddenly stopped and I have a red light on LOS on my outreach box. Service checker tests are saying everything is fine. Done switching on and off but nothing is working - help!
Message posted on 17 May 2025 08:04 PM
Re: No broadband
@84katiejanehughes
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 17 May 2025 08:07 PM
Re: No broadband
Thanks, I've done all this.
rang 150 and it was a 40 minute wait. I bet if I was ringing to upgrade they'd answer quicker 😂
Message posted on 17 May 2025 08:08 PM
Re: No broadband
Following the Sky Q outage the other night 40 minutes is pretty good.
