Discussion topic: No broadband
Message posted on 24 Apr 2025 01:31 AM
No broadband
No broadband. Not working lost connection. Restarted but states no issues within local area?
Message posted on 24 Apr 2025 04:44 AM
Re: No broadband
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't come back on by 0700 use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
