Discussion topic: No broadband
Message posted on 13 Apr 2025 07:53 AM
No broadband
sky max hub slowly flashing green yet checks say it's connected have reset it and still same
Message posted on 13 Apr 2025 07:54 AM
Re: No broadband
@HelenThomas_
This should determine if there's an identified fault affecting multiple households.
Message posted on 13 Apr 2025 07:59 AM
Re: No broadband
Are you on full fibre broadband, do you have an o n t box, or are you still on the old broadband ? If you have an o n t box Are all the lights on or do you one red light on the Los?, if so then the broadband is down, if you are not sure then i would suggest you call sky about this
