Discussion topic: No broadband
Message posted on 11 Apr 2025 12:40 AM
No broadband
I've got a solid amber for Internet. I've turned it off and back on again
Message posted on 11 Apr 2025 05:22 AM
Re: No broadband
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If its still down by 0700 use the below link to check to see if there are any broadband problems or outages nearby
