Discussion topic: No broadband
This message was authored by: Emmatyrrell1990
No broadband
No broadband
Avatar for Emmatyrrell1990
Level 0 icon
Re: No broadband
Need asap I have disabled children who rely on internet
Re: No broadband
@Emmatyrrell1990
There is an outage in parts of Cornwall if you're based there.
Otherwise, if you haven’t done it already use the below link to check to see if there are any problems or outages nearby
