Discussion topic: No broadband
This message was authored by: Kierannneill
No broadband
Hi , the Internet stopped an hour ago and didn't come back I've reset the router 4 times, all the leds are working on the wall mounted network box ,but no Internet thanks kieran
Re: No broadband
@Kierannneill
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
Avatar for Kierannneill
Re: No broadband
Cheers , just sayes when I run a line test there's a problem get in touch
Re: No broadband
@Kierannneill
Give Sky a call when the lines open to report it. Sky will pass it to Openreach to investigate and fix.
