Discussion topic: No broadband
This message was authored by: Ashleyangel1978
No broadband
Our broadband ain't working but saying no issues when running test
This message was authored by: Ryanhyde
Re: No broadband
We have the same issue here, the orange voice light is on our hub as well.
Avatar for Ashleyangel1978
Re: No broadband
Same what area are you were based in Barnsley
Re: No broadband
Yeah we are too in Wombwell.
Re: No broadband
It could be essential maintenance taking place which is usually carried out overnight to minimise disruption. Otherwise check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test. If you get amber or red you need to follow the on-screen instructions.
Re: No broadband
Yea am wombwell too still no internet
