Discussion topic: No broadband
This message was authored by: Richardlittlebu
No broadband
Hi my broadband isn't working
Re: No broadband
@Richardlittlebu
The first thing to do is check to see if there are any outages nearby via this link https://www.sky.com/servicechecker
If there aren't any then try running the line test here https://www.sky.com/help/articles/broadband-diagnostic-start
Once completed, if it reports back that all is good click on 'broadband' to run an updated test.
If you get amber or red you need to follow the on-screen instructions.
