Discussion topic: No broadband servicec
This message was authored by: Nat116
My broadband has lost connection, I've reset it several times and it's still not working
Re: No broadband servicec
@Nat116
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's still down later (after 7am), use this link to check to see if there are any broadband problems or outages nearby.
