Discussion topic: Orange lights on broadband
Message posted on 14 Jun 2025 02:13 AM
Message posted on 14 Jun 2025 05:06 AM
Re: Orange lights on broadband
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back on by 7am use this link to check to see if there are any broadband problems or outages nearby.
