Discussion topic: No broadband for a while
This message was authored by: Jodie1306
I am without broadband for around a week - a house move has ended up with a weeks delay..
for a week, could i buy a 5g mobile router with sim slot unlocked (Netgear or something from Argos) get an unlimited data PAYG 5G sim and stream my tv ? Would that work ?
i dont know what else to do 🙈
i also need to work from home so thought that was an answer to my turmoil
This message was authored by: Jporch316
Re: No broadband for a while
Providing the speed is fast enough it should work .....
Bear in mind you may get the odd freeze or crash
@Jodie1306  Providing you can get 5G you can at least work from hiome, stream pucks may work ok it depends on speed and latency over 5G
