Discussion topic: No broadband coverage
Message posted on 20 Jun 2026 08:30 AM
Just had sky installed in a 3 storey house and have no WiFi on top floor. Engineer said I need an extender for it to work, how do I get one ?
Message posted on 20 Jun 2026 08:33 AM
Re: No broadband coverage
@Paxomp wrote:Just had sky installed in a 3 storey house and have no WiFi on top floor. Engineer said I need an extender for it to work, how do I get one ?
Firstly, unplug the hub for 10 minutes and then reboot.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
