Discussion topic: No broadband connection
Message posted on 10 Oct 2025 06:12 PM
Pon light flashing and data light not on
Message posted on 10 Oct 2025 06:19 PM
Re: No broadband connection
@CO1998
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Message posted on 10 Oct 2025 09:35 PM
Already done this
Message posted on 10 Oct 2025 09:36 PM
Voice light orange there no light on internet and the fiber box has 1 green light again had nothing but problems since we have switched to fiber
Message posted on 10 Oct 2025 10:19 PM
@CO1998 ONT Power and Pon both solid green, Lan flashes with data flow. Dont have that condition then NO internet!
Message posted on 10 Oct 2025 11:32 PM
This is the exact issue I've had twice this week, including right now.
