1
This discussion topic has been answered Discussion topic: No broadband again
This message was authored by: Angelo1956
No broadband again
My broadband is dropping off every 2 minutes, comes back and goes again, this is not the first time l have told u
Re: No broadband again
@Angelo1956
You aren’t contacting Sky Customer Services here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
▪️I AM NOT A SKY EMPLOYEE ▪️
@Angelo1956
