Discussion topic: No beoadband
Message posted on 07 Dec 2025 07:01 AM
No beoadband
There is no broadband connection on the sky box or anything else. I've taken a picture as proof
Message posted on 07 Dec 2025 07:12 AM
Re: No beoadband
@Steph168
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
