Discussion topic: Can't access hub features
Message posted on 30 Nov 2025 09:07 AM
I've just upgrade to the WiFi Max Hub and I have to say not impressed so far. The booster doesn't connect and in the app I just get a message saying there was a problem loading some hub features, so I can't access things like prioritising devices or switching off WiFi on certain devices. Any ideas? I've tried the usual turning router off/on, resetting router and deleting/reinstalling the app. The white light on the booster just flashes the whole time. If I try to set up manually in the app I just get an error message
Message posted on 30 Nov 2025 09:44 AM
Re: Can't access hub features
@dazza-m79 it sounds like the hub has not been properly set up.in the app which is an esential first step see https://www.sky.com/help/articles/set-up-hub-max-hub-do-you-have-internet-calls in some cases you will need to talk to Sky as they msy need to check the settings at their end .
Message posted on 30 Nov 2025 10:56 AM
I've tried going back through the set up process and get to the parental controls section and it just comes up with an error screen
Message posted on 30 Nov 2025 11:01 AM
@dazza-m79 looks like you need Sky to fix it from their end.
Message posted on 07 Dec 2025 07:08 AM
I've had the same issue today !! Driving me nuts ... did you manage to sort ?
Message posted on 07 Dec 2025 07:36 AM
Yes, well kind of! I set it all up last Saturday and everything kicked in on Tuesday. So I suggest waiting a few days and try again.
