Discussion topic: No Wifi
Message posted on 16 Nov 2025 12:39 PM
No Wifi
Message posted on 16 Nov 2025 12:50 PM
Re: No Wifi
@Wayne_B
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
