Discussion topic: Broadband not working and slow speed when it does
Message posted on 16 Nov 2025 12:43 PM
Broadband isn't working and when I've looked I'm only get half of what I should do speed wise normally when it does work
Message posted on 16 Nov 2025 12:51 PM
Re: Broadband not working and slow speed when it does
@Vickyn17 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@Vickyn17
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
