Discussion topic: No Wifi
Message posted on 24 May 2025 10:49 AM
No Wifi
I currently have no wifi it stopped working for yesterday.
Message posted on 24 May 2025 10:51 AM
Re: No Wifi
@TeeBell
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
