Discussion topic: No WiFi
This message was authored by: Bobby3501
No WiFi
In a street of multi 80 and 90 year old  no WiFi and being told to go on
line and arrange check fault .. how is this supposed to work
Re: No WiFi
@Bobby3501
If you are a Sky Broadband customer then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
Avatar for Bobby3501
Re: No WiFi
Yep all good for sav tech 60 year olds 80 plus year old not so easy yep all in the red just checked engineer for Tuesday. Ran to try escalate for all the other 4 90 years old but told as I am not a customer can't help
Re: No WiFi
In a world of competing ISPs that's just not how things work: even if they were Sky Broadband customers you can't log issues for them.
