Discussion topic: No WiFi
This message was authored by: -J1
No WiFi
WiFi keeps cutting off but also saying it's full bars at the same time?? But also presenting Sky EDGE instead of allowing my 4G to kick in. This issue with Sky in this area is beyond a joke works for a day and kicks off again.
Re: No WiFi
@-J1
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
