Discussion topic: No WiFi
This message was authored by: Simon1668
No WiFi
My WiFi dropped out at 11am this morning. I have turned the Sky router off and on but there is no orange light next to the Internet light on it. I have run a test on the MySky app and it says there are no issues with my broadband.
Re: No WiFi
@Simon1668
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
