Discussion topic: No WiFi
Message posted on 19 May 2026 06:35 AM
No WiFi
Still no WiFi this morning - wondered if anyone else is experiencing similar?
Message posted on 19 May 2026 07:05 AM
Re: No WiFi
With about 6 million Sky broadband subscribers a few are bound to have an issue.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
