Discussion topic: Broadband issue
Message posted on 19 May 2026 08:15 AM
Broadband issue
My broadband won't work after numerous attempts I have reset it servrel times unplugged and replugged everything and still no internet connection. Whilst on your checks your saying everything looks fine.
Message posted on 19 May 2026 08:22 AM
Re: Broadband issue
Not our checks. You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
