Discussion topic: No WiFi
Message posted on 09 Jan 2026 10:39 AM
No WiFi
Message posted on 09 Jan 2026 10:41 AM
Re: No WiFi
@Gilfach6
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
