Discussion topic: Internet not working
Message posted on 09 Jan 2026 10:33 AM
Hi I am trying to work from home but my internet isn't connecting to my laptop. The service checker says good connection and my phone connection keeps dropping in and out. I will disconnect the wifi and it was say secured and then as soon as I connect to it it says no internet
Message posted on 09 Jan 2026 10:35 AM
Re: Internet not working
@Serenawwfc
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
