Discussion topic: No WiFi
Message posted on 09 Nov 2025 07:15 PM
No WiFi
Recently had a sky super hub installed but tonight we've got a slow green flashing light for the past hour and no WiFi signal on any devices. I've reset the hub but still have the same issues
Message posted on 09 Nov 2025 07:31 PM
Re: No WiFi
@rabhanna Try the link below!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to displayed by the software test! This should determine if there's an identified fault affecting multiple households.
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR ONT also require to be looked at!
