Discussion topic: No WiFi
This message was authored by: Linzb
No WiFi
4 green lights, ran all tests which say no issue but wifi not working.
This message was authored by: Nimisha3
Re: No WiFi
I am having the same issue
Re: No WiFi
@Linzb @Nimisha3
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
