Discussion topic: My broadband is not working
Message posted on 06 Nov 2025 12:07 PM
Hi, my broadband seems to not be working. This has only just happened and was working fine earlier. I work from home so this is really important. Please can you help?
Message posted on 06 Nov 2025 12:22 PM
Re: My broadband is not working
@Clair02
Use this link to check to see if there are any broadband issues or outages nearby (even if you’ve already tried it)
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
