Discussion topic: No WiFi
This message was authored by: Noname2710
No WiFi
I have no WiFi this morning 15 September 2025 and I had none Friday. It got fixed about 4pm Friday but now it's gone again
Re: No WiFi
@Noname2710
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Avatar for Noname2710
Re: No WiFi
I've done all this and it's all coming back fine when it's clearly not
Re: No WiFi
Then you will need to find a way to report this to Sky and presumably you did before.
Re: No WiFi
Do you have any contact information for them as I can't find anything anywhere
