Discussion topic: No WiFi
This message was authored by: hayleystacey
No WiFi
Hi our WiFi is not working this morning we have done all the checks but still nothing
This message was authored by: Melissa268
Re: No WiFi
Same here
Avatar for hayleystacey
Level 0 icon
Re: No WiFi
Mines ok now I rebooted about 5 times
Re: No WiFi
@hayleystacey @Melissa268 You may be able to see what the Hub is doing by looking at the lights, link below will explain, if it has all just stopped then run the service checker via a mobile data connection, but it does take some time for sky to be aware if it is an area wide fault!
