Discussion topic: No WiFi
This message was authored by: Dude1
No WiFi
Internet and voice lights on the router not lit, had previously been amber most of the day. I have tried all of the Sky suggestions, tried reset button, tried unplugging cables and plugging back in, power on and off, no joy. It had been going off and on intermittently since last night, now those two lights on the router are not lit at all.
Re: No WiFi
@Dude1
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
