Discussion topic: No WiFi
This message was authored by: kennuff.
No WiFi
My WiFi has been on and off all day. I was unable to work from home today and now I am unable to watch the tv recordings.
Re: No WiFi
@kennuff.
Wi-Fi is basically the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Re: No WiFi
@kennuff. If you have a TV recording should be able to watch those with the Internal network!
