Discussion topic: No WiFi
This message was authored by: Nicnak1
No WiFi
Sky box is completely dead, no lights, so no WiFi
Re: No WiFi
@Nicnak1
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Re: No WiFi
@Nicnak1 No lights then either power socket, power psu for the hub, hub has died....
Avatar for Nicnak1
Re: No WiFi
Thank you. Yes your right, on further inspection...the socket is broken 🙁
