Discussion topic: No WiFi
Message posted on 11 Apr 2025 11:30 AM
No WiFi
WiFi isn't working
Message posted on 11 Apr 2025 11:32 AM
Re: No WiFi
Wi-fi or broadband? Wi-Fi is the connection between devices and your router. Broadband is the internet connection provided by your ISP to your dwelling.
