Discussion topic: No WiFi
Message posted on 26 Feb 2025 01:56 PM
No WiFi
I have no WiFi. Middle light on router is off
Message posted on 26 Feb 2025 02:01 PM
Re: No WiFi
@Gareth19772
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
