Discussion topic: No WiFi
Message posted on 16 Jan 2025 12:55 AM
No WiFi
Broadband has gone down again. Sky app is telling me there are no issues 64mb download speed yet nothing can connect to the internet. The baby monitor is down.
This is becoming more regular!
Message posted on 16 Jan 2025 06:42 AM
Re: No WiFi
If it's happening at the time you've posted it's possibly maintenance related. This is done overnight to minimise disruption as most customers are asleep. If it's not back up later use the below link to check to see if there are any outages nearby https://www.sky.com/servicechecker
Message posted on 16 Jan 2025 08:58 AM
Re: No WiFi
Thank you
