Discussion topic: No WiFi
This message was authored by: KG15
No WiFi
All 3 lights are on sky WiFi box but no connection. When prompted to re-enter password on mobile phone to reconnect to WiFi it says 'incorrect password'
Re: No WiFi
Are you entering it as it is printed on your hub so using upper case if required and also using a O and not an 0 or vice versa ?
