Discussion topic: No WiFi
This message was authored by: Chrismol88
No WiFi
Hi, WiFi is down and the LOS on the BT fibre box is red. Thanks
Re: No WiFi
Hi @Chrismol88
Sounds like you will need an engineer unless there is an area fault reported in your account. Have you run the line test?
I am NOT a Sky Employee
Avatar for Chrismol88
Re: No WiFi
Hi,
Thanks for your response, I have contacted sky it seems to be an external fault for open reach to fix.
Many thanks
