Discussion topic: How to port forward???
Message posted on 02 Jan 2025 06:04 PM
Message posted on 07 Jan 2025 05:14 PM
Re: How to port forward???
It is on the app under advanced settings
Message posted on 07 Jan 2025 05:19 PM
Hi
Thanks for responding, where exactly in the app is advanced settings?
The only option I can find is product settings. Which only has options for sky shield and MCaffee
Message posted on 07 Jan 2025 05:31 PM
In the My Sky app there should be an option for your Sky Max hub under product settings. This article might help;
https://www.sky.com/help/articles/change-wifi-max-hub-settings
Message posted on 07 Jan 2025 05:47 PM
Hi
The hub doesnt show up within the app as it should. Says that the hub might not be set up yet which it is and the help just takes you to a link to download the app.
Thanks for the help but looks like Im going to have to call them tomorrow
So frustrating that something that used to take a few minutes now requires an app that doesnt work correctly
thanks anyway
