Discussion topic: No WiFi
This message was authored by: Mark359
No WiFi
No WiFi and phone crackling noise so can't here
This message was authored by: Intelminder
Re: No WiFi
The WiFi is down in my property. I have 2 orange lights being displayed, these are the WiFi & voice light. I have reset the router and these lights are still present. It should be noted, that I am a Sky Engineer, so I'm aware of all the checks that are required. This is definitely an issue with the service and not related to the router.
This message was authored by: daveNOS
Re: No WiFi
@Intelminder As your a Sky engineer you should know that you need to contact customer service to report a fault and get Openreach to attend, the forum members cannot assist with that as we are just customers.
@Mark359 A crackling phone line usually suggests a line fault, you would also need to call customer service to report the issue as it will probably require a visit from Openreach to investigate and fix.
