Discussion topic: No WiFi
This message was authored by: Halfnm10
Message posted on 19 May 2024 09:00 PM
No WiFi
I have no WiFi and it's flashing orange, All your tests say there's I have connect
Find out more
Message posted on 20 May 2024 08:01 AM
Re: No WiFi
@Halfnm10 you are notvtalking to Sky by posting in the forum you will need to call them if want their help. One piint when checking your connection the result the app shows is from the last routine test you need to clickto run the test again if your connection has just gone down. If you do that it will show you if there is a known fault affecting your line if there isnt you need to report it by calling them.
