Discussion topic: No WiFi connection
This message was authored by: Mcalpine
No WiFi connection
My broadband is working on my computer via direct ethnet cable. But won't pick up WiFi connection on any devices. I have sky glass and this won't connect either
Re: No WiFi connection
@Mcalpine common isue this morning if its a white hub reset it by pressing and holding thecwps button on thecright handcedge until the led starts flashing rapidly green then release. When the hub restarts you should see the SSID again.
This message was authored by: RLHar24
I have the White Hub which was the same but after pressing and holding the WPS for 30 seconds and allowing to reset has made it work again.
