Discussion topic: Unable to connect to WiFi...my network is not showing to connect.
Message posted on 24 Sep 2024 06:21 AM
Message posted on 24 Sep 2024 06:22 AM
Re: Unable to connect to WiFi...my network is not showing to connect.
Message posted on 24 Sep 2024 06:27 AM
@Jennifer30 Try to reset your Sky hub which should make the SSID visible.on the newer white hubs hold in the wps button on the right hand edge for at least 20 seconds until the led flashes and rdlease. On the black hubs hold in the reset pin until the power led flashes shich takes 10 to 20 seconds.
Message posted on 24 Sep 2024 07:16 AM
Message posted on 24 Sep 2024 07:25 AM
@Jennifer30 if you have the white hubs it sounds like you did not hold the button in long enough to reset the unit you simple started the wps function the reset flashes are rapid green.. If you have a black hub you need to use the separate rest pin again hold that in until the power light flashes this time red.
Message posted on 24 Sep 2024 07:45 AM
Message posted on 24 Sep 2024 07:46 AM
Same here in Northampton, reseting router doesnt work. Always issues with SKY
