Discussion topic: No WiFi again
This message was authored by: Confused24
No WiFi again
WiFi regularly dropping and unable to connect any devices. I pay a fortune for this service and expect it to work. What is the issue please.
Re: No WiFi again
@Confused24
It could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not back hasn't returned by 0700 use the below link to check to see if there are any problems or outages nearby
Re: No WiFi again
@Confused24
As customers here we couldn't say what the issue is so if you a reboot of your hub doesn't kick it back into life then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
