Discussion topic: No Wi-Fi
Message posted on 10 Mar 2026 01:24 PM
No Wi-Fi
No Wi-Fi after electric went , followed all steps but nothing is helping tried to run dionostics but that doesn't seem to work either
Message posted on 10 Mar 2026 01:29 PM
Re: No Wi-Fi
@ER63 Do you mean your Broadband isn't working, as WiFi is your internal network.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 10 Mar 2026 01:32 PM
Re: No Wi-Fi
Yes broadband, apologies.
i have followed all steps as instructed ie turning on and off checking wires for connection etc but the tv still has no connection.
there were technical difficulties around 2 am last night but everything worked fine after that until around 11.30 ish today
Message posted on 10 Mar 2026 01:33 PM - last edited: 10 Mar 2026 01:34 PM
Re: No Wi-Fi
@ER63 Do you see anything as linked below. It may be the exchange is also out as well and did not recover!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Forget all off the above if it is only your TV not working!
Message posted on 10 Mar 2026 01:36 PM
Re: No Wi-Fi
The lights on the hun and Roger are all on and working
Message posted on 10 Mar 2026 01:37 PM
Re: No Wi-Fi
The lights on the hub and router (not Roger) are all on and working
apologies my phone changes words
Message posted on 10 Mar 2026 01:42 PM
Re: No Wi-Fi
@ER63 Some confusion now, is the HUB working fine and you have broadband internet on your phone or other devices, and the TV is the only one not working, or is it all Green lights across the hub but no data is flowing anywhere so looks like nothing is working at all....
Message posted on 10 Mar 2026 01:46 PM
Re: No Wi-Fi
Sorry about the confusion!
Not really sure what the issue was but it seems to be fixed now
thanks for your help.
