Discussion topic: No Wi-Fi
This message was authored by: Tuffin
No Wi-Fi
We didn't have WiFi this morning then I had a message saying it was back on which it was but not long after it went off again and is still off.
Re: No Wi-Fi
@Tuffin
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
